TwinTurbo.NET: Nissan 300ZX forum - Re: What would cause power steering fluid (atf)
nonstopna
on May 13, 2020 at 1:26 PM
posted by tray15012(pittsburgh)
on May 10, 2020 at 05:10 PM
how severe is the leak through the reservoir? Does it leak more/less when you turn the wheel? how far up did you fill the reservoir?
17:10:46 05/10/20
I've had air in the system cause this. Turning wheel lock to
Ghoztt (MD)
19:38:03 05/10/20
I tried turning the wheel. Doesn’t seem like the fluid
19:41:23 05/10/20
This really belongs in the Technical forum, but is the
Ghoztt (MD)
21:05:16 05/10/20
It does when I turn it all the way to the left
21:46:28 05/10/20
It is Normal for whine/groan at full lock..end of turning
Drk93TT
15:30:01 05/11/20
No air lol. And no hard driving. It just started to do this
19:33:18 05/11/20
If the fluid is foamy, air is getting sucked in.
mrchips
07:41:42 05/11/20
I replaced the all the hoses
09:31:12 05/11/20
maybe overfilled? Used Dexron III fluid correct ? (n/m)
Drk93TT
16:56:43 05/11/20
Yes and def not overfilled. When turning the wheel
19:29:16 05/11/20
Hows the belt tension? That could be the issue
Drk93TT
20:01:53 05/11/20
Feels normal but squeaks when cold. May try to tighten it (n/m)
11:14:45 05/12/20
Re: What would cause power steering fluid (atf) -
nonstopna
13:26:43 05/13/20
Re: Re: What would cause power steering fluid (atf)
nonstopna
13:27:54 05/13/20
^^^False...
itsa300zx
14:21:24 05/13/20
